Strange Brake Problem 97 300ex
Old Mar 30, 2026 | 01:33 PM
Drew4556's Avatar
Default Strange Brake Problem 97 300ex
I have a weird issue where I can use the front brakes no problem, but as I ride or as the ambient temperature warms up the pressure increases in the brake system until it locks the front brakes down and the brake lever is hard. I can then crack the bleeder and everything returns to normal for about 10 to 15 minutes depending on how hard I am riding before happening again. Have you ever experienced this or have any ideas of what it might be?
Old Mar 31, 2026 | 02:47 AM
Yes it is a master cylinder fault. Usually the piston is not returning fully, so the hole between reservoir and cylinder is always covered by the piston. As fluid expands, it can't flow back into the reservoir, so puts the brakes on, creating more heat, so fluid expands more and puts them on harder.
Old Mar 31, 2026 | 06:33 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Yes like merryman says front master cylinder is issue most likely gummy brake fluid and return hole is blocked inside could try to fluid and bleed system real good if not may have to take master cylinder apart clean,and it rare brake line issue
Old Mar 31, 2026 | 02:57 PM
Drew4556's Avatar
I will order the stuff to do a master cylinder rebuild. Any recommendations on a good online supplier? I really hate using cheap Chinese stuff if I can avoid it.
Old Apr 1, 2026 | 02:29 AM
Our non-genuine supplier sells Shindy kits, which seem good quality. However you can buy genuine Honda parts and the bag may have "made in China" on it nowadays.
Matt1980
Apr 24, 2008 05:32 PM
macdady12269a
Mar 3, 2006 12:49 AM
300exredrider
Mar 15, 2001 10:24 PM
