questions on xplorers and other 4x4's
Old May 8, 2001 | 11:49 PM
blazer316's Avatar
Iv'e been wondering if it was possible to change the rear tires on a xplorer 250 to 25's instead of 24's;front 24's instead of 23's sucessfully.Or would that bog it out to much?What tires would you recomend ect. I own a '98 blaster right now and i was also wanting to know if i could possibly trade it with a little money for some sort of polaris 4x4 like an xplorer 250,300 ect.any 90's models would be considered perferibly newer.If anyone can tell me about any of the 4x4 polaris's that's possible for me to get sometime i appreciate it.post here or e-mail me directly at goo0072u@aol.com
Old May 9, 2001 | 09:11 AM
blazer316's Avatar
someone help me out.
Old May 9, 2001 | 09:19 AM
xepathfinder's Avatar
Yeah you sure can, I had a 2000 Xplorer 250 4x4 and the dealer told me I could run titan 489 in 25 inch, just like the ones on the 325 4x4 Magnum, with no trouble also, could run something like 24 inch Black Waters or Bear Claws in 24 inch. the front rim is a 10 inch you will more than likely need to get a 12 inch rim for the larger tires. I was told it has as much if not more power than the 325 motor and is ligther than the 325 4x4. it should be no trouble. also he said stock Sportsman tires work good too. I wanted 24 inch Black Waters thought they would look and work good. you can run the same size front and back, they only reason they are different sized, which is the only 4x4 Polaris that does this is to meet a price point, with the way the 4x4 system works on the Polaris you can run the same size tires front and back.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
cornermike
Sep 10, 2015 08:30 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Slagpolaris
Sep 5, 2015 09:41 PM
Jason Richards
Sep 4, 2015 06:17 PM
