FRONT SHOCK ADJUSTMENT??
Old Nov 19, 1999 | 12:54 AM
jbird23's Avatar
Does anyone know how to adjust springload on the scrambler??? my dealer has no idea
jbird
99 400 scrambler
Old Nov 19, 1999 | 01:15 AM
rooster's Avatar
There is no spring preload adjustment on the front shocks, but the rear shock there is. The only thing you can do is put spacers in the front to stiffen it up, but you can't get it lighter.
Old Nov 19, 1999 | 01:39 AM
dformsto's Avatar
Rooster, in general you are correct, the only comment I want to make is that adding a spacer does not stiffen the spring it only raises the front end (pre-load) by as much as the spacer thickness. The spring rate remains the same. I believe the scrambler has similar spring options as the SP500 and that is two springs are available one stiffer and one softer than standard.
Hope this is of some help.
Dave Formstone 98 SP500
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
