takin the muffler off of the recon
Why are you doing this? If you are try to make it louder or less restricitive. Take out the spark arrester. On the 400ex and 250ex there are 3 screws on the end. Undo them and it should slide out.
I think it would be a good idea if you invested in a manual. This will help you greatly. It shows you how to completely rebuild your quad.
There are 2 bolts holding it up under the rear rack, and there is a clamp holding it to the head pipe.
When I replaced mine I did not see any way to remove the spark arrestor, the whole muffler is welded together.
Other then replacing the stock muffler with an aftermarket one or some other type of service, there is no good reason that I can think of to remove the muffler. It will just make your Recon annonyingly loud and give you a great chance of blowing the engine for running it way too lean. The little bit of performance gain would not be worth the headaches.
exmotocrosser
Sep 13, 2019 06:12 AM
slowgsxr97
Sep 8, 2015 07:33 PM
