Scrambler belt
Old May 14, 2001 | 12:10 AM
jpstercj7's Avatar
I have a problem i have broke my third belt since october.I want to know what belt will hold up.And also who has then and how much.thanx for the help.
Old May 14, 2001 | 12:30 AM
Englishmatt's Avatar
Good year powerstreak is your only answer.I bought mine from Canadian tire but Im sure a good year dealer in tires should be able to get you one .
Hope this helps ?
Matt
2000 500 Scrambler
Reluctantley for sale
Old May 14, 2001 | 12:35 AM
Rainman's Avatar
You can get a goodyear power streak belt from dennis kirk for about $45 on line. www.denniskirk.com
Rainman
Old May 14, 2001 | 12:49 AM
Scram500Man's Avatar
The PowerStreak is a good belt but the degree of the belt is slightly different than stock. This may give you a slight tap from the belt when your RPMs are dropping quickly, Ive had mine on for a little more than a month and no problems to speak of. Check your local Goodyear belt dealers 45$ is way to much I picked mine up for 25$, no shipping extras.
Old May 14, 2001 | 08:23 AM
KevinM's Avatar
HPD has a new belt out that they use on their 75HP engines thats supposed to slip less than other belts. I would think that it would be plenty strong enough for the average person.
Old May 14, 2001 | 09:21 AM
TheQuadfather's Avatar
I would make sure your clutches are lined up first. If you've gone through three already, I doubt the belt is the problem.
Old May 14, 2001 | 08:40 PM
jpstercj7's Avatar
Does hpd have a web site?I have tried hpd.com,but no luck.If anyone knows it please help have to get ready for this weekend.
Old May 14, 2001 | 09:41 PM
AKScrambler's Avatar
HPD's site address is www.hpd-inc.com
Old May 14, 2001 | 09:54 PM
jpstercj7's Avatar
I have checked hpd's web site, and didn't see any belts.
Old May 14, 2001 | 09:57 PM
soggyrider's Avatar
I am afraid I would have to agree with Quadfather, I really don't think your belt is the problem. You need to check the alignment of the clutches, and the belt tension. The dealer has a tool to check the alignment, and to can check everything else yourself. I would seriously consider buying a manual if you don't already have one.
