NEW ho engine probs
Old May 18, 2001 | 12:10 PM
Grizzjeeper's Avatar
Have 125 miles on it, had first service, now make metallic engine rap. Sounds like noisy lifters in an automobile. Dealer says nothing to worry about, yet it definatley doesnt sound like any other ho or magnum.......
What can I do?
Old May 20, 2001 | 02:06 AM
jscyoung's Avatar
Grizzjeeper, if that was my quad, I would get something in writing from the dealer so that you are protected if there is something wrong that doesn't show up until the warranty is off. He should be able to give a logical explanation of what the noise is. Since it is under warranty, why not get another dealer's opinion?
Old May 20, 2001 | 11:51 AM
DieselPro's Avatar
Depends how loud it is. Id definitely get the dealers diagnosis in writing.
Just FYI, there will be an audible ticking sound from pistion slap. Just the nature of the beast.
Old May 20, 2001 | 10:45 PM
mtpockets's Avatar
grizzjeep,
if you don't think it sounds right and your dealer says not to worry, then i'd try a different dealer!
'01 sportsman 500 ho
2000lb warn
26" outlaws on alloys
Old May 20, 2001 | 11:04 PM
RickRitter's Avatar
I would check the buttons in the front clutch , they may be lose . They will generally make racket only at idle when loose . Does this diagnosis match the symptom ?
Old May 22, 2001 | 12:04 PM
rjohns's Avatar
This is the same question I have posted in other forums. I have checked and rechecked the valve clearances. It is coming from somewhere on the recoil side of the engine and sounds like it is a vavle ticking.
Old May 22, 2001 | 10:15 PM
rjohns's Avatar
Anyone else have any input here?
Old May 23, 2001 | 01:26 AM
scareyfast's Avatar
My 2001 scrambler 500 2x4 is also makeing the {lifter tick noise}. I checked mine today with a stethoscope {real cool amplified rig}and have narrowed it down to the starter. A friend of mine, who has several polaris', said his sportsman 500ho had that tick. he found the bushing in the recoil case,on the end of the starter shaft, was wore and he had to do a little machine work and oversize the bushing o.d.[it had eat into the aluminum case apparently].anyway... i'm gonna check mine tommorrow ,, i'll let you know what i find!
Old May 23, 2001 | 01:30 AM
scareyfast's Avatar
Old May 23, 2001 | 10:41 AM
rjohns's Avatar
Now I am really curious! I think I will do some disassembly tonight.
Thanks I would really like to know what you find.I will also post my results!
