what type of polish for polished case?
Today I took my stator cover to school and polished it.It looks real good.I was wondering what kind of polish.(mother's,etc)was best for keeping it shiny.
Thanks
86 trx250r wiseco .020 piston,boyesen reeds,low-mid porting,fmf gold series fatty pipe,power core 2 silencer,Dg alloy series nerfs,JD performance +2 A-arms,durablue eliminator 2+2 adjustable width axle,durablue posi loc axle nut,white bro's white power's with adjustable piggy back fronts,white power rear with adjustable resivor,Ac stadium series front bumper,renthal trx250r bend handlebars,909 grips,fastline braided steel brake lines,d.i.d chain,JT pro series rear sprocket,nac's casesaver,braking brake pads,nac's casesaver,uni filter,pro design kill switch,PEP easy pull clutch perch and lever,polished stator cover,18/11/8 holeshot mx's on mitchell .190's,21/7/10 holeshots on ITP .190's
Thanks
It wasn't to bad.I used 520 wet/dry sandpaper and sand it down a little then polish.THen sand and polish and just kept doing that.It took about 4 hours to get the whole thing nice and shiny.I couldn't quite get it to a mirror because it has lots of larger scratches to.
I didn't know it but we have a polishing wheel for our bench grinder at home.and like 5 bars of compound.I am going to do my cylinder,water pump cover,thumb throttle cover,brake res cover.
And when I get a pro design cool head it should look pretty sweet.I will try to find someone that can make the cases look new again.Well only one I have to buy the shifter side because it is leaking oil a little bit.
Johnny Mac
60
Dec 14, 2019 06:13 PM
