What Do You Ride/ Want Do You Want?
i ride a stock raptor, soon to be slightly modded raptor, maybe later i will go for the extreme mods, but i think i will just put my exhaust on for performance,then later put the axle and whatever else i can afford, i have a bumper coming in, a speedometer/computer i have yet to put on, and i may get an air filter kit,
for what i want, i may buy a 4x4 soon, if the prairie 650 ever gets here, other wise i will buy a polaris, dont know which one yet
I have a 1990 banshee. The frame is PPG paint that changes from blue to purple. The motor is a 370 Longrod with ported cases, ported cylinders ,and cut pistons done by Ohton racing. The timing is advanced 4 degrees. I run v-force reeds valves with ftz racing intakes.It also has a cool-head with 17cc domes pushing 165psi comp. 2 34mm Keihin PJ carbs fire the beast with dual K&N fiters. A kevlar barnett clutch kit keeps the ower flowing. I run Chrome Toomey T-5 pipes. I have lonestar +2 arms on the front with works dualrates shocks with rezzy's. The swingarm and carrier are also painted silver with PPG paint. I run bandits all around for dirt and sand skate 2's with blades on the front for dunes. I run 14/40 gearing. It also has a graydon bumper and skidplates. I think thats all. I am looking on picking up a raptor to run some trails and putt around on.
97 Banshee(broken clutch cable.. dirty as hell)
86 XT600 pretty fast..
93 Nissan Hardbody MTX 10's, MTX 560W amp, JR Custom Bucket Seats, Hot WirZ amp wiring kit, Aiwa CDC X217 CD player, C-Notched, Fully Bagged, Nitrogen charged bags, 5 Lug Conversion,Einki 15x7's, wrapped in Toro 215/60's. Blue tweed dash, Hot WirZ neon light kit, Neon Shift ****, White gauges, Neon Antenna, Sound Activated Blue Neon Lights.. more to come
that's about it...plus all the other lil toys of mine
I ride a 1997 yamaha Blaster with:
Hetrick Midrange Porting and head mods, Wiseco Prolite piston, FMF Fatty Pipe and PC Silencer(custom length), Teflon Reed spacer, Boyeson power reeds, oil injector block-off, sandblasted head, Uni air filter, Keihen 34mm carb, Wiseco piston, Maxxis Razr MX 18x10-8 rear tires on Douglas .190 rims, Maxxis Razr 21x7-10 front tires on Douglas .190 rims, Works front Dual Rate AT Steelers w/rezzies, Works Ultracross rear w/adjustable compression rebound and preload, Works blue shockcovers, AC polished nerfs w/blue netting and AC polished grab bar, Renthal Bars, Pro Design tether kill switch, dirtbike style pushbutton kill switch, front racing fenders, Maier Handguards, Renthal 14 tooth sprocket, MSR EZ pull clutch lever and perch, Blue Scott grips, Silver stator cover (custom cut for easy sprocket changes) and silver side case cover, sharpened footpeg grips, shorty brake lever, DG Baja chassis skidplate, Polished case halves, polished thumb throttle cover, EBC rear brake pads, and RK Racing O-ring chain.
