Cranks, but doesn't start
Old May 28, 2001 | 08:43 PM
Dalliwacker's Avatar
I have a 96 Polaris 300 Xpress. The other day while out on a hunting trip I fouled out a spark plug...the first since I purchased the bike. After replacing the plug it started like a dream and didn't have any problems until I returned home and found out today it is doing the same thing it did while on my trip earlier. This time it doesn't appear to be a fouled plug though. I checked the plug for sparks and that was good. I also checked the fuel filter to make sure fuel was running through good, and that appeared good. I did put in a GL of gas I had sitting outside all winter before I left on the trip, and even assuming there was water in the gas, it should have given me problems while out riding over the weekend...right? Regardless I through some HEAT into the resevoir. Should I check the oil line? I am far from being a mechanic, but I don't mind tinkering with things within my capabilities. Especially if it will save me some dough. Any input would be appreciated. Thanks!
Old May 29, 2001 | 12:56 AM
ZoomZoom's Avatar
Hard to say from here but I'll give it a shot. Is the sparkplug damp with gas after cranking it over a few times? If not maybe the float needs reajustment, or the carb needs cleaning. Maybe the float bowl is full of water?
Old May 29, 2001 | 03:14 AM
Thanks Zoom,
But I figured out what the problem is...a 5 year old air filter that needs replaced.
Old May 29, 2001 | 03:50 AM
ZoomZoom's Avatar
well I'll be darn! That's a quick & easy fix. Nice work on fiquring that one out.
Old May 29, 2001 | 03:54 AM
Maybe quick, maybe easy, but if I know Polaris they are going to charge me an arm and a leg. Anyone know if you can get atv filters at NAPA or elsewhere? I tried calling today and they were closed due to Memorial Day.
Old Jun 2, 2001 | 10:49 PM
MagicMatt's Avatar
Any good mail order company should be able to assist you with this filter. A Uni Foam Filter (better protection) will run you $19.95, a K & N filter (better air flow) will run $39.95. Service your filter every 3-5 hours of use for the best engine reliability, otherwise piston and ring wear as well as connecting rod failure will be just around the corner. Good Luck.
Old Jun 6, 2001 | 11:52 PM
springdrl's Avatar
I have been using a small engine filter that I purchased at an auto parts store for less than ten bucks.
Come on guys, how fancy does a fuel filter need to be?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
jrooker6
Jun 17, 2015 12:28 PM
1000gade
May 27, 2015 12:37 PM
