power trip !
Old Jun 22, 2001 | 04:52 PM
KKKILLER250X's Avatar
i want to bore out my 250X .80 over and put in a mild cam . will i need the stronger valve springs w titanium valves and hardface rockers , if i run it without those parts will it break ? and also will this decrease reliablility? and what piston should i go with i heard wiseco seazes really easy ? i was thinkig about a niks Please help !!!!!!!!!
Old Jun 22, 2001 | 07:12 PM
wcy2k400ex's Avatar
I'm not sure if you would need the hardfaced rockers, stronger valve springs, and all that are necessary with a mild cam. It should certainly increase reliability compared to without I'd think, but I don't know if you'd need it. That probably depends on the cam you decide to get.
Also, if you plan on boring .80 over, I would get a higher compression piston. You have probably already thought about this anyway. Wiseco seems to be a good piston, just as JE, Niks, and the other known brands are. Hope I helped. Good luck.
Old Jun 22, 2001 | 07:15 PM
i think my piston is allready 12 to 1 how much higher can i go without running race gas
Old Jun 22, 2001 | 09:09 PM
?????????????????????? alittle help please !
Old Jun 22, 2001 | 10:01 PM
crhye250r's Avatar
To be honest, im not positive that there is a piston for the 250X higher than 12:1. If i were you i would contact TC Racing, or Curtis Sparks. They would be glad to help you with this question im sure.
Old Jun 22, 2001 | 10:02 PM
bermbanger's Avatar
I think 12 to 1 is about as high as you can buy them.
Old Jun 22, 2001 | 10:05 PM
i saw a 250x bored to a 410 with a 14 to 1!!!! http://www.off-road.com/atv/250XRS.htm
correction 14.75 to 1 that is one rip $h!t 250X
Old Jun 22, 2001 | 11:16 PM
bermbanger's Avatar
Yeah but 14 to 1 isn't going to be all that reliable, and you would have to run a really high race gas or octane booster which would cost some $$.
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
JakeXBL
Sep 5, 2015 01:08 PM
