anyway to fix this?
Old Jun 24, 2001 | 12:41 PM
MiStA400EX's Avatar
i was just wondering if there is anyways to fix a hole in the sidewall of a tire, the whole is in the front tire on my 400 and i really dont feel like buying a new tire just becuase of this little whole. i mean the front tires are still look pretty new. any help would be great,
Chris
Old Jun 24, 2001 | 12:55 PM
leadman's Avatar
If it is a small hole & not on a stress point, you may be able to plug & patch.
1/ pull a plug through from the inside out, using glue
2/ grind the plug flat on the inside/ rough the area
3/put glue on & let dry
4/ install a patch over the pluged area.
this may help, on a larger tire you can section a area in the side wall but I don't think it would hold on a small soft sided sidewall.
