Shocks: Can someone explain all the "Jargon"
Old Jun 28, 2001 | 12:09 PM
RotGutBottom's Avatar
In laymen terms, what is rebound, preload, sag, compression and all the other terms used when setting up a shock? What happens when you adjust the preload and compression?
How do aftermarket shocks differ from the stock shocks on a 400ex?
Thanks for the help
Old Jun 28, 2001 | 01:17 PM
CP's Avatar
CP
If you go to www.Shocconnection.com there is a "Common shock question" part that you can go into. It may not answer all you questions but it will help.
Old Jul 4, 2001 | 01:26 AM
CBRSLIDER's Avatar
Hey check out the Custom Axis Website. They have a tech manual online that you can look through. I learned alot about the different terms pertaining to shocks from the manual. Check it out at www.customaxisshocks.com
Ray
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Aug 6, 2015 10:46 AM
Polarisman1123
Aug 3, 2015 02:08 PM
ltrmc02
Jul 22, 2015 04:50 AM
DJS
Jun 28, 2015 11:34 AM
