250R Jetting advice??
Old Jul 8, 2001 | 01:05 PM
letitsnow's Avatar
I have an '88 that has a .010 stock piston, rad valve, fmf fatty pipe. I run Bel ray oil at 40:1. I haven't finished putting this all together yet and was wondering if anyone could tell me a good main jet to start with. I think the stock main jet is a 158? This motor isn't ported and uses the stock carb. Also, what heat range of plug should I use? NGK 7, 8, 9? I ride in MN so elevation isn't a problem. Thanks in advance.
Old Jul 8, 2001 | 06:03 PM
ugly's Avatar
Well on my 86 the stock main was a 150.I am now using a 152.I have a FMF gold series fatty pipe and silencer,A little bit of port work,boyesen reeds,uni filter,a .020 wiseco piston.
IT runs a little rich just a little.lately it has been acting spot on though.I haven't fouled a plug in a long time and it is a little brown like it should be.But during the winter it was acting rich.
I run maxima castrol 927 at 32.1.And I also run a 50/50 blend of race fuel and premium pump gas.
Old Jul 9, 2001 | 10:32 AM
sweetcorn's Avatar
does the race gas make it faster?
Old Jul 9, 2001 | 12:15 PM
Dill's Avatar
letitsnow: I'd start with a 160 main (probably fat, but better safe than sorry) needle clip in the middle position, and a 50 pilot..when my R was stock, I ran a 158 main, 50 pilot, and needle in the 2nd clip from the bottom, and yes, I'm in Mn too, if you have problems, I make it up that way frequently, so maybe I could swing in and help you out.
Old Jul 9, 2001 | 05:14 PM
ugly's Avatar
No it doesn't make it faster.I just run it that way to help and keep the engine clean.My dad and some guys that I used to race with sadi that race fuel burns hotter and cleaner.
Plus it smells cool.
Old Jul 9, 2001 | 09:20 PM
letitsnow's Avatar
Thanks for the advice Dill, i'll try what you said. What range spark plug do you use? Thanks again.
Old Jul 10, 2001 | 01:07 PM
Dill's Avatar
I run a 9 right now..I do mostly higher speed riding, so it works fine and doesn't foul out...if you do alot of real slow trail riding and putting around, run an 8.
Old Jul 16, 2001 | 08:42 PM
fivel250rman's Avatar
I have an '88 with a FMF silencer,stock pipe,.005"head gasket,cylinder spacer,'86 boostported .010"Pro-X piston,6mm reed spacer,V-Force reed cage,stock carb,and a K&N filter with outerwear.My main is 162,pilot is 40,needle clip in the 2nd groove,airscrew at 2and1/4.Hope I helped.
"88 250R many extras
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Canamaniac!
Sep 15, 2015 06:19 PM
