What about lightening the flywheel on 400ex??????
Old Jul 9, 2001 | 11:00 AM
Aaron10's Avatar
I heard of some people doing this. What exactly is done? Is it worth it? How about reliability?
Old Jul 9, 2001 | 11:51 AM
BigGun's Avatar
This is something that a do it yourselfer can't do. It must be left to a highly compitent machine shop with experience due to needing to be kept properly ballance and or counter weighted. It reduces the rotating mass and weight so the engine can rev quicker, no real hp gaines, maybe a ponie or two, if that. But talk a bout spinning up quick, whoo.
Old Jul 9, 2001 | 12:11 PM
Aaron10's Avatar
I hvae a local shop that will cut me a good deal. But does anyone know about how much this would run? If done proper, is reliability no question?
Old Jul 10, 2001 | 10:20 AM
trx250Rob's Avatar
It's a big waste of money, you might get 1 or 2 more HP but you will lose alot of torque and reliability. I did it to an 200x years ago and after spending about $350 the only difference was that it would stall easier if I didn't rev the engine high before letting out the clutch. Biggest waste of money ever. Don't do it.
Old Jul 10, 2001 | 10:54 AM
madweazl's Avatar
Its been done on every kind of engine for years now. You will loose your low speed idle because there usually isnt enough weight left to maintain a smooth idle. You will gain some power but it probably isnt worth the money it costs to have it done, spend it on something else that will yield more power and drivability.
Old Jul 10, 2001 | 12:57 PM
86atc250r's Avatar
Reliability is not a really a question if done right. Ridability is.
Seriously question your motives for doing this. Honda spent a lot of R&D setting up the proper flywheel weight for the 400EX's engine, gearing, & weight.
You risk making your 400 stall easier and produce less low end torque for grunting over techincal terrain.
If you look to the dirtbike world, most people are ADDING weight to their flywheels, not removing it.
Unless you are strictly into drag racing, it's a bad idea.
Old Jul 10, 2001 | 05:05 PM
Aaron10's Avatar
I beleive i will stay away from doing this after hearing you all's opinion's. Appreciate the advice guys.
Joe454
Nov 20, 2020 01:19 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
