250t dead
Old Jul 10, 2001 | 04:16 PM
toyz's Avatar
I recently bought a 83atc 250r which had to be leaned out to rev up. I took it to a dealer which said it was the cdi. The cdi quit and i got a new one from a wrecker. Now it will not fire at all. The carb is fine. The reeds are fine. Compresion is 125 PSI. Timing is about 5 Degrees before TDC. There is fuel getting to plug as i can wet it out if i try. Tried pull starting. It will not fire at all. Please help as i do not want to take it bake to shop.
Old Jul 10, 2001 | 06:25 PM
bermbanger's Avatar
Don't you think it has low compresion? Check for an air leak.
Old Jul 10, 2001 | 06:53 PM
AdamPhillips's Avatar
pull out the plug and put it back in the boot and try startin it with the plug out. watch the plug to see if it sparks. if theres no spark u got a bad CDI box and need a new one.
Old Jul 10, 2001 | 06:54 PM
check the plug wire and the coil too.
Old Jul 10, 2001 | 09:42 PM
toyz's Avatar
The timing was done with an auto timing light. There is a good spark. The coil was exchanged with a known good one. Also tried a couple of new spark plugs. The compresion might be a little low but it is an air cooled engine and this should make it not fire???
Old Jul 11, 2001 | 08:48 PM
MP250R's Avatar
<< The timing was done with an auto timing light. There is a good spark. The coil was exchanged with a known good one. Also tried a couple of new spark plugs. The compresion might be a little low but it is an air cooled engine and this should make it not fire??? >>
Motor Basic 101: You need 3 things to make a motor run. Fuel, Spark and compression. If you have good Spark and I am assuming that you have fuel in the tank, then it is compression. 125 lbs is awful low. I would check into that more.[img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 11, 2001 | 11:37 PM
bermbanger's Avatar
I've always heard an engine won't start with the kickstart at 125 or lower. It should be at 190 probably.
Old Jul 12, 2001 | 02:39 AM
trapperb1's Avatar
The problem is most likely electrical.
Compression of 125 is low but it should start. I had a half melted piston in my R and was able to kick start it with my hand and it still ran (badly and no power but it got me back to camp). Compression of 190 is not necessary; 150 is fine.
Old Jul 12, 2001 | 04:49 AM
booneTRX's Avatar
I had an 83 R also. My actual timing was 90 degrees out because of a faulty coil. Contact a good bike shop about replacing your stator assembly, since Honda does not sell individual coils. The mechanical timing seemed on. Ricky Stator also has stator plates. I replaced mine and she screamed on the first kick!!!!!!
Could be similar problem with yours......bad pulsor coil.
Good luck
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
