alba A-Arms
Old Jul 13, 2001 | 01:12 AM
sand45's Avatar
Anybody running team alba upper a-arms, and if so how do you like them!
Old Jul 15, 2001 | 03:50 AM
Knutz's Avatar
I've had them on my quad for several months and love them. They stabilize the front at speeds well above 80 MPH. The fit was completely perfect and constuction was top quality. They have even been upgraded since the set that I installed so that they now have a much better, patented, ball joint at the spindle.
By the way, I sell them as well. If your interested in ordering, e-mail me[knutzconcepts@msn.com] or call at (702)236-6852, between 8:00 A.M. and 7:00 P.M. Pacific time, Monday-Friday.
Old Jul 16, 2001 | 12:49 AM
sand45's Avatar
Sorry! I just orderd them on friday,are they easy to install and whats the most criticle part on the installation?
Old Jul 16, 2001 | 01:55 AM
Knutz's Avatar
They are very easy to install. The most critical part is to ensure that they are equal, to avoid uneven handling.
I put the front of the quad on a jack stand under the frame and used a clamp to hold the stearing stem strait. I took a 12" steel rule placed on the spindle and measured the angle with a gravity angle finder. [$7.00 at Home Depot] I then removed the stock arms and installed the adjustable arms. Re-measure the angle using the exact same points on the spindle. I set my caster at 3 degrees more than stock. I set the camber[measured at the hub] at 1 degree farther in at the top than stock. I hope this helps you.
Old Jul 19, 2001 | 12:17 AM
sand45's Avatar
Just recieved my alba a arms they look like top notch stuff! thanks for the info knutz. COOOL!!!!!!!
STLyamwar
Jul 25, 2020 04:44 AM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
DFWSRT8
Aug 20, 2015 09:24 AM
musselmark
Jul 17, 2015 02:40 PM
