recon dies?! WHY!? HELP!!!!!
Old Jul 15, 2001 | 10:35 PM
pyromaniac442's Avatar
When I have my recon in neutral and rev it up..it will not hold a rev higher than half throttle..it dies out. If I put it in gear and give it gas it will move a little bit and die out! SOMEBODY PLEASE HELP....I need help fast...Thanks!
Old Jul 15, 2001 | 10:48 PM
RedRecon's Avatar
Try and drain yor float bowl and then see what happens. My recon does this sometimes after i go through REALLY deep water and some water collects in the float bowl. Hope this helps!
Old Jul 15, 2001 | 11:10 PM
Hey redrecon...can you please tell me how to drain the float bowl? I have never done this and I really hope to get the recon back up and running for tomorrow. Thanks a lot!
Old Jul 16, 2001 | 03:10 AM
2002GRIZZ's Avatar
I think to drain the float bowl you have to find it first then take out the screw that goes right up through it then it should come off then you can dump the water/fuel out.
Old Jul 16, 2001 | 01:29 PM
I have never done anything like this and wouldn't know which screw or what it is? I know where the idle adjustment screw is. But do i have to take the carb apart or anything for this? I don't know how to do it...I need some instructions...lol
Old Jul 16, 2001 | 05:33 PM
bermbanger's Avatar
Look where the overflow pipe attaches to the carb. There should be a screw there..lossen it up. My dads 300 Suki did this once and it turned out the needle came off and stuck in the main jet. Take the carb off and go thru it. I'm betting the main jet is clogged with junk.
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
2many2ride
Sep 27, 2015 04:35 AM
Jason Campbell
Sep 7, 2015 02:25 PM
