What would the stroke be on my Scrambler 400???
Old Jul 30, 2001 | 10:13 PM
Xplor's Avatar
I am calculating the compression ratio and need this figure. I know what the figure represents but do not know the amount. I can't seem to find it.
Old Jul 30, 2001 | 11:04 PM
JoshCVBz's Avatar
Brian,
I believe it's 83mm bore, and 70mm stroke. Hopefully somebody else can confirm.
-Josh
Old Jul 31, 2001 | 12:37 AM
HyperSport400XC's Avatar
Piranha,
You are correct sir, YES! An 83mm bore by a 70mm stroke.
Old Jul 31, 2001 | 12:40 AM
JoshCVBz's Avatar
My goodness...
Miracles never cease [img]i/expressions/face-icon-small-happy.gif[/img]
-Josh
Old Jul 31, 2001 | 02:38 AM
modquad's Avatar
Hey Brian,
just in case you need it, the 83mm bore converts over to 3.2677". The 70mm stroke converts over to 2.7559". Straight from the Polaris manual.
KT
Old Jul 31, 2001 | 02:45 AM
modquad's Avatar
P.S. you'll need a thick, and perfectly flat piece of plastic, or glass. Some grease, to make it seal. A science lab buret, and some water. These items are for CC'ing your cylinder head. Remember to install a sparkplug, to duplicate it's intrusion into the chamber. Seal the edge of the head with a thin film of grease. Place the glass or plastic ( with one each hole drilled) over the head. Proceed to slowly fill the chamber to accurately measure it's cc's.
KT
Old Jul 31, 2001 | 11:17 PM
CaptNemo's Avatar
A 50cc syringe will substitue for a buret. You can get them from a hobby store that sells R/C model cars and aircraft ( from SIG ) or from a veterenarian or feed store if you're not in a larger city.
Old Jul 31, 2001 | 11:47 PM
Xplor's Avatar
I ended up using a childrens medication 10ml syringe. It worked great. I tried something out of the blue: I installed two head gaskets which brought down my compression to a more suitable point. (155psi) I will run 100 octane fuel and see how she runs. Hopefully this will work.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 4, 2001 | 07:26 PM
bdscram1's Avatar
its a two - stroke!!!!!!!!! Thats why you mix the gas and oil for lubriction. if you need any more help just let me know. Im just being a smart a@@
Old Aug 5, 2001 | 01:29 AM
Ronnnnn's Avatar
Why dont you buy the billet head with the dome for the kind of gas you want to run? You wont have to go through all the fuss and worrry about gas plus it cools better.
