Hey Rick Ritter, could I bother you for a moment?
Old Aug 28, 2001 | 01:04 PM
waynaferd's Avatar
I was just curious how large you could bore a 38mm Mikuni flatside out to, and what you think it would cost. Its for a 87 Quadracer 500. Thanks.....
Old Aug 28, 2001 | 05:22 PM
RickRitter's Avatar
I charge $60.00 to do that for that carburetor .
I think back in the day the happiest folks had changed that carb to a Keihin 39 . That was a long time ago , and I don't recall what the complaint was off of the top of my head with the stock carb .
Take care ,
Rick
Old Aug 28, 2001 | 07:59 PM
HyperSport400XC's Avatar
Rick,
I can tell you why I went to the 39mm Kehin, it simply flows better than the 38mm Mikuni. With the 38, I was getting a flat spot around 3/4 throttle where the carb wouldn't flow any more. This is gone with the 39mm Kehin. It flows very well all the way to WFO. I would be afraid of going any bigger for fear of losing what little low end I have. I do know that some people do bore the 38 mm Mikuni to 42 mm, but that seems a tad excessive to me. Unless you're running in the sand, and have a top end pipe or an enormous overbored motor it seems redundant to me to bore the 38 to 42mm. Now the Suzuki Quadzilla might benefit from it, but the Polaris I have probably wouldn't.
Old Aug 28, 2001 | 09:08 PM
RickRitter's Avatar
The carb on that bike is a 38TM , not a 38TMX . It had metering problems of some sort on that bike although I can't recall exactly what it was.
It can be bored properly ,unlike a TMX, which you can't really do correctly. I am just hesitant to advise doing it on a 87 500 Suzuki .
I have seen the taper bored 38 TMX otherwise known as a 42mm taper bore .The carb is not bored all the way through , but tapered to the widest point (42mm) at the engine side of the carb , the venturi is still 38mm. I have tested a 39PWK , a 38TMX , and a 42TMX taperbore on a flowbench .
The results were interesting . The 39 PWK comes out on top , and the 38 and 42 taperbore flow identically . I believe the difference was about 7% flow at WOT between the Keihins and the Mikunis .
Carb makers should follow automive leads , and rate the carbs by flow rate , and not diameter . It makes selecting carbs hard , when the numbers may , or may not mean a thing . Example , I have seen a aftermarket that was a 28 , that was for replacing a 26 on an older quad , suprise, the 26 outflowed the 28 .
I suspect the folks taperboring the 38TMX into a 42 are doing so as to send a stronger pulse to the jets , to make the metering sharper .
PS Hi Mike , it's been a while , how are ya ?
Old Aug 29, 2001 | 12:21 AM
waynaferd's Avatar
Ok, thanks alot. I was kinda leaning towards a new Keihin 39 PWK anyhow, but I was just wondering about gettin' the stock one bored....
Old Aug 29, 2001 | 02:05 AM
Dazed's Avatar
Rick what is the addy to your web site i can,t find it ????
Old Aug 29, 2001 | 10:12 AM
AZ400L's Avatar
It's www.rittercycle.com
Rick, I have a question at Jack's forum pertaining to porting if you can spare a few minutes?
Old Aug 29, 2001 | 12:53 PM
Hey Rick,
I'm doing pretty good. I ran my right hand through a pane of glass yesterday and with qualification (handgun and shotgun) coming up it might be a little difficult, thank goodness I can shoot lefty. My next project is steel braided brake lines for the 400. If they work well I'm going to put them on the 250 as well. I have the lines (from the local Polaris dealer), but I really hate playing with brake fluid. Oh well the nature of the beast and all that...
On another note, I just read an article in the latest issue of Dirtwheels dealing with the LT500. Guess what carb they put on it. Yep, the 39mm Kehin PWK.
QuadRiders
Oct 22, 2015 04:13 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
fredrikrosen
Sep 28, 2015 09:58 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
awer1968
Sep 8, 2015 11:02 AM
