650 Seat Problem
Old Aug 30, 2001 | 12:16 PM
kevin_staton's Avatar
A guy that I ride with on a regular basis has a problem with his seat coming unlatched while riding. Anyone else have this problem?
Old Aug 30, 2001 | 01:41 PM
PrairieDust's Avatar
He is not latching it in correctly. There are two tabs that are a bit of a pain to get in until the seat has been on and off about 100 times.
Old Aug 30, 2001 | 02:46 PM
He gets the tabs at the front and the latch at the back. So what's the trick to getting the others? How can you tell if you hit mark with them?
Old Aug 30, 2001 | 05:35 PM
Just make sure to get the middle tab in by pushing down on the front of the seat while sliding it forward. I was putting mine on thinking that both tabs at the front were in but the middle one was not. Then just smack the rear of the seat and it should latch. If not I would see your dealer.
Old Aug 31, 2001 | 09:04 AM
prairie633's Avatar
If you get tired of trying to get the middle latch to engage the hoop, you can just cut if off. I had to cut mine off because I mounted a hard box on the rear rack which makes it impossible to slide the seat back enough to catch the middle tab. For a couple of weeks the middle tab was just sitting on the top of the metal hoop. Once I cut it off is works fine and I can't tell any difference in the stability of the seat when the front and rear is properly latched.......
toonces
Jul 16, 2015 03:19 PM
WilliamBos
Jul 13, 2015 02:11 PM
tricky123
Jul 12, 2015 05:51 AM
Albertascramblerx
Jul 8, 2015 11:56 PM
Shifts
Jul 3, 2015 07:59 AM
