What kind of oil?
Old Aug 31, 2001 | 11:38 PM
madweazl's Avatar
Its time for an oil change on my Mojave, what kind of oil should I use? Can I just pick up some 10wt30 synthetic stuff at the local parts store or do I need something special?
Old Sep 1, 2001 | 12:59 AM
Raptoryfn660r's Avatar
RIP Dear Friend
If it calls for 10w-30 I would use it. I don't think you need anything special. I would use what they call for during warranty period. I make my own blend for my machines. I have never had any clutch problems. I do change my oil often. Do a search on oil. You will get all kinds of posts. Might even be one in their telling you water is a good thing. Just kidding. Chet
Old Sep 1, 2001 | 01:56 AM
99mojave's Avatar
hold on just follow me thru this im an automotive tech and have been for many years... first off use oil no snytec what ever... second run 20-50 castrol or valeoline there very clean oils with no ash deposits etc.... in the winter it you ride go to 15-40 that will be fine.. oh change the filter .. also good day........ Jim.
Old Sep 1, 2001 | 04:43 AM
RIP Dear Friend
Snytec or synthetic. Thats a big difference. Thats two different base stock of oils. Chet
Old Sep 1, 2001 | 07:07 AM
boxofrokx's Avatar
I always use dino oil. Synthetic and cluches don't go well together.
Old Sep 1, 2001 | 08:44 AM
2000MOJAVE's Avatar
There was a discussion on this in one of the other forums and some one scaned an article from some research they did in a mag. The skinny is that the automotive oils are as good and/or better than the "atv" oils Yamalube the Kaw stuff etc. It did say not to run lower than I believe it was 10w40 in a wet clutch system. If you look on the back of 10w30 it will say energy conserving II or something like that and those oils have friction modifiers or something and they claimed it will cause clutch squeel. I run Mobil 1 15w50.
Old Sep 1, 2001 | 10:25 AM
PrairieDust's Avatar
www.redlineoil.com
This stuff rules!!!
Old Sep 1, 2001 | 10:37 AM
springdrl's Avatar
Try to use an oil that carres a more narrow viscosity range, say 10W-30 as opposed to 10W-40. You'll get more oil and less non-lubricating additives per unit volume.
I have also had outstanding performance while using Valvoline.
Old Sep 1, 2001 | 06:58 PM
extremelean's Avatar
A little FYI
Use an oil that is made for an ATV or motorcycle.......car oils have a lower shear point.....car oils do not run through transmission gears or a wet clutch(please keep this in mind when you buy your oil).
Motorcycle / ATV type oils have a higer polymer count for a higher shear point for running through transmissions & wet clutches.
If you insist on using car oil....make sure you change it frequently,as it will breakdown much quicker....especially under severe use.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
