Gas leak on 2000 325 Mag
Old Sep 6, 2001 | 01:44 PM
jimmy50's Avatar
I have drained the float bowl on my 325 mag and now it leaks gas is there a gasket behind the drain screw?? Also if I fill the tank full to the top the gas leaks out from some where. Any ideas of what to check??
Old Sep 6, 2001 | 07:53 PM
soggyrider's Avatar
The gas leak from filling the tank to the top is the gas coming out the vent hose in the top of the tank. Don't fill it so full. As for the Carb leak I can't help you hetre I have not dinked with the carb yet. Good luck I am sure somebody here can help you though.
Old Sep 6, 2001 | 10:36 PM
Polarisman3210's Avatar
Where is the gas coming from, the overflow?
Old Sep 7, 2001 | 12:15 PM
jimmy50's Avatar
The gas leak is comming out of the carb float bowl drain screw.
Old Sep 7, 2001 | 01:05 PM
500SCR's Avatar
Ok, I had the same problem with my Scrambler and it turned out to be a crack in the bowl. I have tightened the screw to tight and it caused a crack in the bowl. How tight did you tighten the screw? If it isn't that, then try some threadlock tape on the screw. I thought it was coming from my drain also but since it is the lowest point it will look like that is where it is coming from. You have to pull the tank and then the carb to get to the float bowl to check it. Good luck!
Scott
Old Sep 7, 2001 | 02:55 PM
jimmy50's Avatar
I think that is what I did was over tightened it. I think you can just buy the bowl I hope.
Old Sep 7, 2001 | 06:39 PM
soupcan's Avatar
There seems to be a lot of this going around. It recently happened to mine, my neighbors brand new TB, and another friends quad.
The guy with the Trail Boss fixed his by blowing just a puff of air up the overflow tube with his air compressor. He said this sometimes works to get the needle/seat to seal again. But he warned just a puff otherwise you could do damage. Mayby the easiest thing to do is just keep your gas line shut off while not in use, unless someone likes to dink around with carbs.
2000 expedition
2000 lb warn winch
Old Sep 7, 2001 | 06:47 PM
500SCR's Avatar
You can get the bowl and I think it is like $32 or so. Good luck
Scott
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
