Idle adjustment?
Old Sep 7, 2001 | 12:59 PM
500SCR's Avatar
I have a 99 Scrambler 500 and need to adjust the idle. I can adjust it where the 2 cables tie together just below the the throttle but it is either to high or dies. Is there another spot to adjust it?
Thanks
Scott
Old Sep 7, 2001 | 04:23 PM
sixty9cobra's Avatar
there is a adjustment at the carb, look for a big thumbscrew pointing down should be easy to find. By adjusting the cable you will mess up the e.t.c. switch adjustment. ETC=electronic throttle control, if you make the cable to loose and it cuts the spark.
Old Sep 7, 2001 | 06:50 PM
500SCR's Avatar
That cable is broken on my carb and I have adjusted that part in as far as it would go anyway. I think I have figured out the problem, it wasn't actually the idle adjustment it was the air fuel screw.
Thanks
Scott
Divergent12
Aug 19, 2023 05:26 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
MNatv89
Jul 7, 2015 11:36 AM
