335 is still pulling
Old Sep 10, 2001 | 11:38 AM
Deepcut5's Avatar
I have checked the air pressure and the tires look to be toed the same. What else could cause my quad to pull to the right and how can I fix it?
Old Sep 10, 2001 | 11:51 AM
PADZZ's Avatar
I once had a 335 w/ the same prob. I changed the hub fluid and the problem went away. Try that
Old Sep 10, 2001 | 04:30 PM
ATV_MAN's Avatar
Could be your tie-rod ends, mine does the same thing...the tie-rod ends are loose and worn out making the tire move inwards or outwards, making the quad pull to one side.
Old Sep 11, 2001 | 07:56 AM
imported_sixty9cobra's Avatar
could be a stuck brake caliper, bad wheel bearing or a stuck hub.You need to narrow it down somehow.
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
awer1968
Sep 8, 2015 11:02 AM
