Dead 300ex
Old Sep 14, 2001 | 05:46 PM
ex_master's Avatar
well my 300ex is dead
I can't get the thing to run..
A few days ago my exectric start wouldn't work but i found the problem (loose flywheel) I tightend it up ... checked everything , spark, gas the works took the carb apart .. cleaned and adjusted it ... STILL won't fire ... I sat there for a few mins today and it just won't work .... It let out a huge backfire and that was it.
Old Sep 15, 2001 | 04:42 PM
ugly's Avatar
Well if your flywheel was loose U may have damaged your stator.
How good is the spark?Is it weak?
an engine needs 3 things to run.
Fuel
spark
compression
U just have to find which one or combonation of the 3.U said it back fired.Which may mean it is running rich.I have heard of a bike doing a similar thing to yours because they didn't have the carb slide in right and it was running WOT all the time.Have U changed the jets?IF so how big did U go.It would be your pilot jet not your main.
86 trx250r
97 300ex
Old Sep 15, 2001 | 04:53 PM
ex_master's Avatar
Its got perfect spark .. it just won't fire... I know this because i got about 5 shocks trying to check the spark.
Old Sep 20, 2001 | 04:21 PM
416EX's Avatar
If the flywheel was loose then you prob spun the flywheel key and after tightening it down the timing is off. Take the flywheel off completly and replace the key with a new one then bolt it all back together. Bet it fires right up.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
DM2015
Sep 7, 2015 10:36 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
