any suggestions for removing a tight warrior axle nut
Old Sep 16, 2001 | 08:59 AM
Madmike101's Avatar
My buddies warrior is down for the count. His inner axle nut is so tight we took two pipe wrenches and 4 foot fence posts as handle extensions and pulled. They inner nut will not budge. Any suggestions on how to break it loose? We are useing the lefty loosey & right tighty thinking on this.
Old Sep 16, 2001 | 10:15 AM
NotuRaptor's Avatar
You could always cut it off with a Dremel.
Old Sep 16, 2001 | 10:30 AM
jefffoxsr's Avatar
It should have come loose. look very closely at the threads leading into the nut and you'll know which way to turn it. You must be going the wrong way.
Old Sep 16, 2001 | 10:55 AM
skydog's Avatar
Well if you still can not get it Heat it up!!You should put new seals and bearings in it anyway! Skydog
Old Sep 19, 2001 | 01:10 AM
ridnwarrior's Avatar
Heat it up with a torch before trying to take it off. Don't get it too hot though.
Old Sep 19, 2001 | 02:07 AM
54warrior's Avatar
Heating it with the torch is the best bet, and to loosen the nut, you should be prying up towards the fenders. Good luck
Old Sep 19, 2001 | 12:03 PM
IceMan11's Avatar
I'd clean the threads off real good, and keep a coat of WD-40 on it for a day or two. Then break out the propane torch... If that don't work I'd take off the axle carrier (with the axle in it) and take it to the local machine shop. They could probably cut them off.
Old Sep 19, 2001 | 12:31 PM
RobS's Avatar
This may sound crazy but instead of soaking it in wd-40, use PB Blaster. It can be purchased at auto zone, even found it at walmart the other day. I have been using it on my old Jeep CJ-7's for years to loosen rusted parts, it is really amazing stuff.
Old Sep 19, 2001 | 07:50 PM
Tooey's Avatar
I had that trouble with my warrior last time i changed my bearings. I let i soke over night in blaster busted loose the next day..
Old Sep 22, 2001 | 12:39 AM
chasman's Avatar
heat it up and then use a big 24" cresson wrench for leverage. Maybe even try that before heating it up.
