Bolt on Recon tire keeps coming loose...somebody plz help
Old Sep 16, 2001 | 02:31 PM
jeffman's Avatar
The back tire on my Honda Recon keeps coming loose. What should I do? Would it be ok to use Loc Tite on it?? Or is there anything else that I could use? Need some advice...
Old Sep 16, 2001 | 04:27 PM
250rampage2's Avatar
First off, make sure that you are putting the nut on the right way (taper facing in), and are torqing it up to the right specs. Then, if it still comes loose, check to see if your tapered bolt holes have been worn out of round at all. This will make the nuts come off. If it comes down to using loctite, make sure you use the blue (service removable) type.
Old Sep 16, 2001 | 09:55 PM
pyromaniac442's Avatar
250rampage told you everything that i know to tell you..i have another question though about my recon..maybe someone here can help me. The last time i asked the question i got some smart allec reply... But my recons front brakes do not grab very tight..If i am going in 1st gear they are slightly effective when i pull them back all the way..if i am going at any kind of high speed you couldn't notice if they were on or not. Can somebody help me or make suggestions on how to fix this? I have tryed the front brake adjustment in the owners manual but it does not seem to work. I brought it in one time for this reason and they said the front brake adjusters were frozen up. It happened again though and i don't want to bring it back to the dealers because they charge an arm and a leg to do anything and they like to mess around with you and won't tell you anything right. Not very good dealers at all. So can anyone here tell me how to fix this problem i have? Thanks to anyone that replies. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 17, 2001 | 04:39 PM
You may need to bleed your brake lines...It's fairly easy, but time consuming, and is best done with two people. If you don't have a service manual, I suggest getting one. They really come in handly.
Old Sep 18, 2001 | 12:07 AM
Thanks, I am planning on getting a service manual..i had one ordered but they were out of stock so i have to order again...oh well
Old Sep 18, 2001 | 01:11 AM
DWavs's Avatar
<< The back tire on my Honda Recon keeps coming loose. What should I do? Would it be ok to use Loc Tite on it?? Or is there anything else that I could use? Need some advice... >>
Hehehe........
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
kwackermann
Jun 24, 2015 10:18 AM
Jun 24, 2015 01:40 AM
Jun 10, 2015 12:45 AM
