Loud ticking noise from my 400ex.
Old Sep 20, 2001 | 03:31 PM
cbrown400ex's Avatar
From what I've read and heard I think this is caused by the valves needing to be adjusted.(please correct me if I'm wrong) Has any of you had experience with this and could give me some info. on how to adjust them. Is it difficult? Could I really screw anything major up? How much would it cost at a dealership? Thanks ahead of time for the help. CJ
Old Sep 20, 2001 | 04:09 PM
NotuRaptor's Avatar
If you are a perfectionist type of person, it is fairly easy to adjust the valves. You will need feeler gauges that are bent on the tips to make it easier. Check your quad parts store to see if they carry the one made by Motion Pro.
Check out www.exriders.com under the tech section for detailed instructions.
My biggest advice to you is:
1) powerwash your quad after removing the gas tank and front and rear plastic.
2) Go to a marine shop and get some teflon-based grease and grease the front steering stem bushing before putting the front plastic back on.
If you decide to get a shop to do it, it should run about $45 since it takes no more than 1 hour. You might be able to get them to do it for less if you take the plastic and gas tank off yourself. This is not so higly technical process that requires a certified Honda shop to do.
Go for it!
Old Sep 20, 2001 | 04:22 PM
Thanks for the help. I don't think I'll have any trouble with it. Do you think this is what the problem is? The ticking noise isn't that loud, but is definitely noticeable. Thanks again, CJ
Old Sep 21, 2001 | 12:14 AM
jeffman's Avatar
Its either you need your valves adjusted or your valve spring popped off. Thats what my 01' 400EX did. The Honda place said that alot of people have been having that problem, and warranty DONT cover it!!!
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
