Rubicon Transmission Problems?
Old Sep 25, 2001 | 08:36 PM
plunker's Avatar
I'm intersted in buying a 2002 Yellow Rubicon when they come out in January but I'm a little anxious about the Transmission, they changed the design to an automotive style for the new Rincon and I'm wondering why.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 25, 2001 | 10:37 PM
TEXMud's Avatar
I dont think they changed it. If you look at the tech specs for it the wording is the EXACT same.
Old Sep 26, 2001 | 12:13 AM
N2Mountains's Avatar
Mine has been rock solid.... The Rincon has an automotive type, with a torque converter & 3 speed auto. I was at Richfield this past week when Honda showed it off. Unfortunately they didn't hang around very long & I missed seeing it.
Old Sep 26, 2001 | 12:41 AM
JRM's Avatar
JRM
The rubicon is a rock solid dual range 5 speed ESP shift/auto hydro mechanical for work and play, the Rincon is a Tire smoken single range tranny with a true torque converter and stall speed (you can build power by holding it agenst the converter) that has 3 Drive ranges, much the same as the Rubicons D1 and D2 and is geared for more play than work.
Old Sep 26, 2001 | 06:47 PM
hiofcer's Avatar
24 Years owning Hondamatic's and Not 1 transmission related problem.
Old Sep 26, 2001 | 11:58 PM
atvhog's Avatar
No problems here, its been 100% rock solid. But, I must admit that I to was a little bit nervous about the tranny. So, for the first time in my life I purchased and extended warranty on it.
Old Sep 30, 2001 | 08:56 PM
thenewfiebullet's Avatar
I'm not doubting what your dealer told you, but I happen to know that there have been some problems with the transmisions. I'll let people with Rubicons go into details.
Old Dec 17, 2001 | 09:11 AM
rockingred's Avatar
I have a 2001 Rubicon and have transmission problems. What the problem is when I am low gear unders stress, like going up a steep hill, the trasmission grinds. It sounds like it is going out of gear. When I stop and start again it works again. This happens when I am snow plowing also. I have taken it to 3 dealers, and they cannot fix the problem. Anyone else have this problem?
Old Dec 17, 2001 | 10:27 AM
TEXMud's Avatar
Have you tried to adjust the shifting linkage.
Old Dec 17, 2001 | 08:11 PM
JRM's Avatar
JRM
sounds like a "sub" transmission problem and not the true tranny...
Joe
