Is installing a Highlifter kit on a 98 Big Bear 350 5 speed a good or bad idea?
Old Sep 25, 2001 | 11:09 PM
kpwhite's Avatar
I realize i asked this question a couple of days ago, but i am at a lose as to whether it's worth the cost.
Will it affect the chamber, toe-in,or does it affect (reduce) the life of the suspention?.
Are there any pitfalls to installing this kit?.
Thank's for any info.
Old Nov 6, 2006 | 04:33 PM
bearclaw's Avatar
Default Is installing a Highlifter kit on a 98 Big Bear 350 5 speed a good or bad idea?
From what I read I can only add 1" lift to my 99 b/bear,is it worth it ,I put 26" tires on and it's better.
Old Nov 7, 2006 | 04:42 PM
BawgBoy's Avatar
Perfex makes what they call a 1.5" kit for the 99 bear (measures closer to an inch) that works well on my Bear, I'm running 27's on stock rims and they never rub.
Old Nov 7, 2006 | 05:53 PM
bearclaw's Avatar
I didn't think that 1.5 " was worth it ,maybe I'm wrong. I thought about the 27" tires but I didn't want to loose any power. I have the 10 speed so I should have gone with taller tires. The 26x12 0n rear and 26x10 on front work great though,never been stuck, YET.
Old Nov 8, 2006 | 10:56 AM
BawgBoy's Avatar
There is definite power loss with my 27's, but with jet kit, pipe and K&N I was pretty much back to stock, just added the new piston and overbore last week and she's really alive now. Keep in mind also that the 27" lites don't weigh a whole lot more than the stock Dunlops so you are simply dealing with the gearing being taller, not much for extra weight. If you have a 10 speed you'd be laughing, mine is only the 5.
Old Nov 8, 2006 | 02:36 PM
bearclaw's Avatar
How much does the over boar give,can you calculate the ccs,I would think that polishing and porting the head would be a better way to go. What did you use for a better pipe?
Old Nov 8, 2006 | 03:40 PM
BawgBoy's Avatar
Doesn't give you much more for cc's, but the compression ratio is now 10.25:1 vs stock 8.6:1 (or close to that). Also a lighter forged piston.
My pipe is a Supertrapp IDS2, works great.
Old Nov 8, 2006 | 03:49 PM
bearclaw's Avatar
BawgBoy I'm from Seaforth Nova Scotia, 15 mi. east of Dartmouth
Old Nov 9, 2006 | 08:55 AM
BawgBoy's Avatar
Wow, small world, I'm in Hammonds Plains now, need to update the sig but still not far from Seaforth. You still living in Ont.?
Old Nov 9, 2006 | 10:17 AM
bearclaw's Avatar
Yes, I'm still here, I have been out your way before,in the 70's My ex brother inlaw lives at Indian harbour. I have been here since 1966, haven't been to Seaforth in 24 yrs. Go to NFLD a lot though.
