What is molybdenum disulfide grease ??
Where can I get this stuff?? Everywhere I call has no idea what I'm talking about. I want to properly grease the seals for the driven pulley when I add a small spacer back in on Friday. I don't want to risk wasting the seals by using the wrong grease since this is a high temperature and high friction area between the seals and the shaft.
Thanks.
Thanks.
"Bel-Ray" makes this grease,standard issue for motorcycle shop......might be labeled as assembly lube.
"Motul" also makes it.
Check out www.motul.com
www.belray.com
www.belray.com
