Sportsman 400 4-stroke as fast as a 400 2-stroke?
Old Oct 10, 2001 | 02:07 AM
ZoomZoom's Avatar
Some peaple claim their 4-stroker can do 59-60 mph. Is the 4-stroker geared different or is this just plain bull? I know my 2-stroke easily does 60+ mph.
Old Oct 10, 2001 | 02:19 AM
mudmunster's Avatar
it is true mine can go 55-60 easy (flat road).
Old Oct 10, 2001 | 09:37 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
NOT EVEN CLOSE!!
THe two stroke will smoke it like a cheap cigar!
Old Oct 10, 2001 | 11:37 AM
MegaCrash's Avatar
If both motors are completely stock, the 400 2-Stroke will make about 8-10 horse more than the 400 4-Stroke. If they both run the same top speed, then the 2 stroke is in desperate need of a taller front sproket.
The manufacturers do overgear some quads a little, just to keep them slowed down. 70 MPH on any quad is scary fast. The tires on these things are not designed for that, and they get real unstable at that speed. Throw in a 4X4s awkward chassis and its that much worse.
Old Oct 10, 2001 | 01:30 PM
JoshCVBz's Avatar
I doubt it because my friends 500 Magnum is a fair ammount slower than my friends Warrior, and the Warriors run at about 59-60mph. My Sport runs about 3-4mph faster than the Warrior (estimated).
However, if the 400 4-stroke Sportsman is faster than the 500 magnum then it's possible.
-Josh
Old Oct 13, 2001 | 06:23 PM
ftwflh's Avatar
I have both a 400 2 stroke Sportsman and a 425 magnum(which is the same engine as the new 400 sportsman)and the 400 2 stroke will smoke the 425 in speed and power but it is not as trail friendly as the 425.400 has too much raw power for tech trails but is GREAT in the mud. Brad Hurt 1996 425 Magnum 4x4 1996 400 Sportsman 2001 125 Breeze (sons)
Old Oct 13, 2001 | 07:53 PM
ZoomZoom's Avatar
This is interesting so far.FTWFLH, what would be the weight difference of these two machines? I know that between my 97 Sportsman and a 2001 Sportsman there is close to 100 lbs between the two. Anyway I don't doubt the 2 stroke to be much faster, but I still have doubts about the 4 stroke being able to keep up with a 2 stroke. Remember we're comparing 400's here and not 500 etc... Not sure how that Warrior (above post) can have anything to do with my question, do they also have a 400 cc engine?
Old Oct 13, 2001 | 10:18 PM
ftwflh's Avatar
you must have misunderstood me my 2 stroke is a lot faster than my 4 stroke.and the magnum is 35 pounds heavier.I do like both machines for differant things.As for my 425 keeping up with the 500s it is lighter and has chains (no shaft to steal power)but a real pain to adjust.
Old Oct 15, 2001 | 09:49 AM
JoshCVBz's Avatar
<< Not sure how that Warrior (above post) can have anything to do with my question, do they also have a 400 cc engine? >>
I said that for comparison purposes.
In an earlier post you said that a guy said that his 400 4-stroke would run 59-60mph. A friend of mine has a 500 4-stroke and my Buddies Warrior will smoke it from start to finish. The Warrior tops out at 59-60mph, so what I'm saying is that if the 500 4-stroke is faster than the 400 4-stroke (which sounds logical) then I don't think that the 400 is running near 60mph.
See what I mean know?
-Josh
Old Oct 15, 2001 | 12:11 PM
ZoomZoom's Avatar
Yeah I read yah right, ftwfth, it's just the way my post sounds I quess. I agree with you.
Thanks for clearing that up for me Piranha. A warrior probably doesn't weight 600+ lbs either but that's still plenty fast.
