Motor starving for fuel during hard cornering
I am running a modded 426ex and my jetting on all three circuits are pretty close. The motor runs fine all through the powerband.
The problem happens only when I slam a corner, i'm not talking cornering fast, i'm talking not letting off, hitting the berm full throttle and staying in the throttle. When I do this, the motor stumbles as if starving for full or bogged, then comes right back on fine. I don't have a float level gauge, but I do have calipers.
Has anyone ever had this problem? There has to be a fix, I should be able to rail full throttle. This one is stumping me. Thanks for the help.
Nick
Nick
Dude, I had the same problem with my 426ex.....Come to find out, my air intake boot that hooks my head to my carb had a crack in it.....when the bike hit hard or rollled in a turn, it suck alot air....check you entire system for leaks....make sure you air tube is well connected between your carb and air filter......Let me know if you find any leaks.....
TLC
Jul 11, 2015 02:28 AM
