Need help Jetting a 400ex
Old Oct 20, 2001 | 05:58 PM
DEPALMA's Avatar
I need help on what size jet to use. The pipe I bought is the White Brothers E series, K&n air filter and Jet Kit. With the stage one the jet they tell you to use is smaller then the stock Jet. So I will be using the stage 2, K&N says if you are below 3000 feet use the 170 if you are 3000 to 6000 feet use a 165jet and 160 if you are above 6000 feet.On the dyno jet needle K&N says groove #3 below 5000 feet or groove 2 above 5000 feet. This is a stupid question are they talking above or below sea level? I live in New Jersey which is at sea level, so what jet should I use. They also state to remove the air box lid on the stage two jetting. On my 300ex I had the same set up but used and FMF power core pipe and never removed the lid, I never had a problem. Thanks for the help.
Old Oct 21, 2001 | 10:42 AM
RAPTORAZ's Avatar
From the info that you have provided, I'd say that they want you to run the 170 main and put the needle clip on groove #2 with no airbox lid. If you want to retain the airbox lid then I would suggest using the 165. Every engine is different and only trial and error will give you the perfect jetting combo.
Old Oct 22, 2001 | 11:34 AM
MIA416EX's Avatar
Keep in mind, the main jet sizes on Kehin (400EX stock) jets are NOT on the same "scale" as the main jets in DynoJet Kits from K&N. And due to the needle taper being different on the K&N Jet kit, a 150 K&N main jet WILL flow more gas than a 150 Kehin Main Jet, using the stock needle.
If you dont want to mess with the airbox, go with Stage 1.
OR go with the Stage 2 recommendations, and either run without an airbox lid, or do like I did and put a 6-inch port in the box lid. I would not touch the needle, and stay at or below a 160 K&N main jet.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
