Bayou 300 Chugs at High Speeds
Old Oct 21, 2001 | 10:46 PM
pdeviney's Avatar
I have a problem that I hope someone can help me with. I have a 2001 Bayou 300 4X4. I runs fine at low to medium speeds. When I try to run at full speed it chugs. Like it has bad gas or something. I took it in and $170 later it does the same thing. They said a float needle sticking, so they replaced the float valve. Does anyone have any ideas? Is this normal? Thanks.
Patrick
2001 Kawasaki 300 4x4
with GUNRACKS!
Old Oct 21, 2001 | 11:29 PM
markdf's Avatar
It sounds like you're running way rich. When the throttle is open from 2/3 to full open, the main jet carb circuit is used. The needle jet carb circuit is used from about 1/3 to 2/3 throttle. You could decrease your main jet size in SMALL incrementts to see if the problem goes away. If you lean it out too much, it will overheat and worse case the engine will seize.
Talk to your mechanic and see what he recommends and if he'll do it. You should know what you're doing when re-jetting. There are a number of articles that talk about it on the web. Spend some time and search for them and read them.
Mark
Nondem
Feb 22, 2020 12:20 PM
Big bousse
Sep 26, 2015 10:42 AM
Aug 11, 2015 11:56 PM
black_thunder
Jul 28, 2015 11:05 PM
bpegram84
Jul 22, 2015 08:15 AM
