Lakota Jet kit Problems
Old Oct 24, 2001 | 04:27 PM
CoyEverage's Avatar
I put the DYNOJET KIT IN FOR MY LAKOTA. Something is not right. It accelerates as slow as a bus and after I get to half throttle it doesn't accel. any more. I still can twist the throttle all the way around butt no acceleration. I have a stock pipe and intake, but I have drilled a few holes in my snorkel and cap , does this matter? I will appreciate any help any one can offer. Coy
Old Oct 24, 2001 | 05:10 PM
gaff's Avatar
coyeverage,
This sounds like the slide isn't opening.
First take the top off of the carb, like you did to remove the slide to drill the lift whole.
It sounds like that diaphram on top is not installed correctly. double check it.
I'm not sure of your mods but it sounds just like a slide staying shut.
If you want to check this, find a way to look into the back of the carb and hit the gas. The slide should jump rite up.
Good Luck!!!
Old Oct 24, 2001 | 07:35 PM
everage's Avatar
Gaff, thanks for comming to the rescue, I did kinda what you said. I took of the air cleaner uct where it reaches the carb and stuck my finger in it and turned the throttle, it doesn't move .. whats up should it move ?
Old Oct 24, 2001 | 08:47 PM
gaff's Avatar
Yes it should move.
I want to let you know I haven't had the lakotas carb apart yet, so my statements are blanket statements for all cv carbs.
The top cover (on top of the carb) remove this, you should see a rubber diaphram. Thier is a outside grove that the lip of the diaphram fits in, insure that the diaphram is in this grove and then the cover will seal it.
Even a hair out will upset the vaccum flow required to move the slide.
This is a simple most common problem with the complaint you discribed.
Also while you have the top cover off, insure thier is no pin holes in the diaphram. The diaphrams are pretty tough so you maybe still alright.
Old Oct 25, 2001 | 12:04 PM
mojaveaddict's Avatar
everage,
You say you stuck your finger in and twisted the throttle and the slide did not open. You did not say whether or not it was running. It must be running to get the slide to open because it takes engine vacumn to open it. Try to look in and see the slide while you gas it with it running, your hand and finger will disrupt the air flow some if you use that method.
Also, without it running you can stick your finger in and raise the slide all the way up and then let it go. If it slams down hard and fast you have a problem with a vacumn leak. It should return a little slow and not slam against the bottom.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
