What carb size for a 250cc 2 stroke?
Old Oct 26, 2001 | 02:55 PM
Orlando's Avatar
For a 250cc 2 stroke engine that only has boyesen reed and exhaust (no porting) what would be a better carb to get a 36mm or a 38mm. Currently my trike has the stock 32mm Mikuni. What do you guys think?
Old Oct 26, 2001 | 05:50 PM
trapperb1's Avatar
If you haven't done anything else to your engine, the stocker is just fine. If you go larger it may help with top-end power at the expense of bottom-end. The smaller carb will help with bottom-end. Another option is a taper bore, this will give you advantages of both. For a stock engine, the 38mm will be too much. I still run the stock 34mm on my 250R due to the fact that the motor isn't ported or bored out. I've even seen 34mm on 300cc 2 strokes and they're just fine.
Old Oct 26, 2001 | 11:18 PM
trx250Rob's Avatar
I just dropped a 38 into my R with no visible loss in botton end from a stock 34. The bike does have some port work though.
Old Oct 27, 2001 | 01:19 PM
lonestarbanshee's Avatar
I have a Sudco racing Keihn 38MM on my R.. It works really well, but I have mid-porting. I agree with trapper, unless you have motor work done, dont get a different carb.
Is something wrong w/your Tri-Z? Is that why you're asking?
Old Oct 27, 2001 | 02:30 PM
Orlando's Avatar
There is nothing wrong with my Z. I am just trying to decide what will be my next mod. I think I have too tall gearing and I thought that if I get a bigger carb and an exhaust I will be able to pull stronger with my current gearing istead of removing a teeth or two at the rear sprocket. I think my stock is too small, it is a 32mm Mikuni (not a 34) like most 250s. I also notice last week that if I do not close the fuel gauge I can see some fuel going out of one of hte car hoses but maybe it has been like that I and just notice it now. I am leaning toward a 36mm but I am not sure yet.
Old Oct 28, 2001 | 01:02 AM
crhye250r's Avatar
I have a Duncan Racing/Keihin 36mm on my R. I love it. It actually improved bottom. I am running FMF Torque reeds and a fatty pipe (stock bore, no porting). I would reccomend the Duncan/Keihin 36mm.
kelleycully
Sep 15, 2016 02:57 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Jul 7, 2015 11:00 PM
