removing CV axles on a Praire 650
Old Nov 11, 2001 | 02:10 PM
northarkie650MUDD's Avatar
i have to replace the cv's on my praire out of pocket because the boots got shredded. but that is a different story. the problem i am having is that the upper cv joint(next to the front differential) wont come out on either side. im afraid to just yank on it or pry it, can anyone help me?
Old Nov 12, 2001 | 08:16 PM
500DUSE's Avatar
Did you check for a retaining clip(snapring)?
I played hell changeing my boot until I found that....Duhhh
Old Nov 12, 2001 | 09:11 PM
where would i find this retaining clip?
Old Nov 12, 2001 | 11:30 PM
D84's Avatar
D84
Just did one on my 400 today. Take the inner CV boot loose, wipe away some grease and use a screwdriver to pop a snap ring out that alows the CV joint to come out with the axle.
Old Nov 13, 2001 | 02:55 PM
well i got mine off, turns out it was all in the wrist. just pusht the cv in a little ways, and pop it out.
Old Nov 14, 2001 | 01:17 PM
Elrancho's Avatar
Most CV's ( automotive, and atv )and I'd assume the prarie'd be the same-simply have a circular ring that fits either in the diff or on the shaft, to pull the halfshaft( and CV) simply apply pressure with a pry then yank. The honda's don't have enough play in there to push then pull but glad it worked. ( The honda halfshaft sits very close to the diff with a steel lip that fits in a grease packing outside the oil seal. )
Old Nov 14, 2001 | 02:06 PM
dont ever use a screwdriver to remove the cv you can damage the seal.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bmark0610
Sep 7, 2015 09:42 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
snowolson
Aug 31, 2015 03:51 PM
