how may cc is 0.40 over
Old Nov 14, 2001 | 10:35 AM
misfit400ex's Avatar
how many cc is 0.40 over
Old Nov 14, 2001 | 11:13 AM
IceMan11's Avatar
Just do the math...
A stock 400EX bore is 85.0mm x 70.0mm. That's 8.5cm x 7.0cm.
So then,
pi * (8.5/2) squared * 7 = 397.20 cc
.40 over is,
pi * (8.54/2) squared * 7 = 400.95 cc
So, by boring it .40 over, you only gain about 3 cc.
Old Nov 14, 2001 | 12:00 PM
Backcountry's Avatar
You're missing a zero. .4 is four tenths of an inch, nearly half of an inch.
.040" is 40 thousandths and would apply to your desire to bore larger. Could be expressed as .04...4 hundreths as well.
Old Nov 14, 2001 | 05:43 PM
IceMan11's Avatar
Hrmmmm... Ok. That change things a bit. The calculations would look like this then:
.040" = about .1016 cm
pi * (8.6016/2) squared * 7 = 406.76
Which comes out to about a 9cc gain.
Old Nov 14, 2001 | 11:50 PM
LilManOn400ex's Avatar
so then 0.80 over is a 416 on a 400ex?
Old Nov 15, 2001 | 01:39 AM
Stroke9's Avatar
Don’t forget about the conversion of standard to metric. There is 25.4mm per inch so (0.04 inches) in metric is 0.04*25.4=1.016mm. Add this number to the bore then calculate for displacement.
Old Nov 15, 2001 | 11:43 PM
TrX465's Avatar
JUST GET A SPARKS 13:1 92MM PISTON AND BE HAPPY .....SPLIT THE CASE HAVE THEM BORED OUT GET A CARILLO ROD HAVE IT TRUED AND WELDED LIGHTN THE FLY WHEEL , GET BIG SLEEVE, RUN A DUCATI CARB WITH A ALCOHOL KIT AND HAVE A BEAST AT LEAST I WHOOP *** WITH IT
EDIT: sorry for the caps
dandam1700
Jun 12, 2014 02:23 PM
Keith Anderson
Jun 2, 2012 05:08 PM
xplorer 400 4x4 with modifition
Mar 22, 2010 09:38 PM
killerfast
Oct 15, 2003 08:52 PM
