how do you change oil after installing full skids?
Old Nov 25, 2001 | 11:02 PM
norcalatver's Avatar
I installed full DG skids on my 400Ex a month ago. I just changed the oil today and what a mess! When I took the drain plug out of the side case the oil went all over the top of the skid plate. What have you done to remedy this problem? Thanks for any info, Dave
Old Nov 25, 2001 | 11:37 PM
LilManOn400ex's Avatar
maybe u could take off the skid plate then put it back on when ur done... i dont know for sure just a thought
Old Nov 25, 2001 | 11:56 PM
Sandgod's Avatar
Uh........ drill a hole in the skid plate where the drain plug goes.
Old Nov 26, 2001 | 05:46 PM
phaskell's Avatar
there is nothing that you can do because you have to drain the tank too so you will just have ti live with taking it off.. i do
Old Nov 26, 2001 | 07:16 PM
I can't believe DG made the skid plate so that you have to remove it every time you change the oil!! I think I'm going to try drilling some holes in the bottom of it where the hole is. Hopefully most of the oil will drain out through the holes instead of all over the skid and then all over my driveway!!!!![img]i/expressions/face-icon-small-mad.gif[/img] Phaskell, thanks for the reply. Those other two obviously have no experience with a 400 Ex and full skids. I was hoping that someone with experience would have figured out a way and passed the info along.
Old Nov 26, 2001 | 09:32 PM
KILLER250R's Avatar
Well I just had a thought, dril yourself a hole and put a small funnel in-between (sp) the skid with the tip sticking out of the hole and the top right underneath the drain plug so you won't get any oil on your skid. Hope that works, just trying to help.
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
95wolv
Jul 21, 2015 12:25 PM
