Raptor clutch replacement
Old Dec 5, 2001 | 11:32 AM
slappie's Avatar
I am going to replace the clutch in my 2001 Raptor. I can figure it out but if someone could scan in the pages from the maintenance manual, that would be great. My dealer doesn't have one and I need it by tomorrow. Thanks a lot.
Old Dec 5, 2001 | 01:23 PM
BlueLeader's Avatar
get a new gasget from Yamy
drain oil and coolant
remove peg and break pedal
remove clutch cable and lever at case
remove water pump
remove all bolts (1 under water pump cover)
remove cover
remove springs (note the torque), fibers and plates
replace all with heavy duty. hand tighten the springs
IMPORTANT: keep bike in neutral and don't mess with the shift lever. you could push the spline out and cause the shift fork to fall below the "thingamajig". the case cover holds the spline in. (Raptor720 saved me a tone of time and aggrivation on this one. Thanks)
bolt it back up.
Old Dec 5, 2001 | 03:30 PM
slappie's Avatar
Thanks for the help. I really appreciate it and I'll follow these directions and hope it works out.
Matt
brad wheeler
Jul 13, 2015 11:19 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
