A question for Prairie 400 & 300 owners
Old Dec 7, 2001 | 11:00 AM
boxofrokx's Avatar
I have a prairie 300 4x4. Last night I was giving things a tightness check. I noticed the the front drive shaft (from the motor to the diff) is loose on the diff end. If I grab that end I can move it maybe 1/8th of an inch, enough to make noise. My question, is that normal? If not, what do I need to fix? Thanks for any help you can give me.
Charlie
Old Dec 7, 2001 | 08:32 PM
Hayashi's Avatar
Charlie,
I'm riding KVF300 4x4 also. When you say you can move 1/8", you are moving axially, not rotating, right? There are spring loaded shims, thickness ranging from 0.1 mm to 1.0 mm, in the front diff gear box. If your machine runs OK (no excessive gear backlash noise or popping out of gear, etc.), I would listent to Murphy.
Old Dec 7, 2001 | 11:03 PM
robbieg's Avatar
i have a 01 praire 300 and i noticed the samething. had dealer chek it out when he was doing the front bearings under waranty. said it was normal
Old Dec 8, 2001 | 07:52 AM
boxofrokx's Avatar
Hayashi, If I grab the cv joint I can move it up and down. I cannot rotate it. The quad does run fine and there is no oil coming from the area.
Robbieg, your dealer said its normal. It worries me every time a dealer says something is normal. It could actually be normal or they are just to lazy to do the work and hope you will go away.
I guess for now I will measure the actual movement and see if it gets any worse.
Thanks for your help
Charlie
Cole Hadden
Jun 15, 2025 09:05 AM
austinwhitton
Aug 11, 2015 06:21 PM
coolguy420
Jul 28, 2015 01:54 AM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
