REEDS
Old Dec 9, 2001 | 01:39 PM
Madscrambler's Avatar
Which is the best reed setup for the 400 v-force or boyesen rad valve
Old Dec 9, 2001 | 01:49 PM
Ronnnnn's Avatar
If the rest of your bike is running great it wil still run great and have great performance with either kind. I personnally run v-force but I doubt very seriously if i would notice a seat of the pants difference if I switched to boyesen.
Old Dec 9, 2001 | 10:48 PM
CaptNemo's Avatar
The Delta's are the hot set up. Get a reed cage spacer to install with it.
Old Dec 10, 2001 | 03:10 AM
modquad's Avatar
The dynos prove it, V-force is better. Like they said, use the spacer, it helps protect them.
Ken
Old Dec 10, 2001 | 06:05 AM
MUDDY4LIFE's Avatar
I have the Delta V-Force in my 400cc Xplorer.In my opinion,it was a waste of 150 bucks.Add another 25 bucks for the spacer and its a waste of 175 bucks.I felt NO increase in speed or performance.Keep in mind,I have NOTHING official to base my observations on EXCEPT a seat of the pants feel while accelerating.
If you want to make a real differance and not kill your pocketbook,change your primary spring over.You'll notice a seat of the pants differance here and it'll cost you around 25 bucks.
Good Luck,
Bill
Old Dec 10, 2001 | 12:56 PM
modquad's Avatar
Bill, I have to agree with you if you don't have any other mods, you probably won't feel a performance gain. When you look at the big picture of a ported and piped engine, they enhance the flow (lots of air in and lots of air out) completing that "Air-pump" enhancement. Baseline, a clutch kit and a pipe are probably the two best initial mods a person can perform, and REALLY feel it. Reducing wt also helps, especially getting rid of the oil injection tank.
Ken
Old Dec 10, 2001 | 03:00 PM
Mike Chero's Avatar
Bill,
I'm in agreement with modquad. Did you re-jet after installing the reeds? Believe it or not, the reeds actually make the engine run slightly richer (every other mod makes the motor run leaner). Drop down a jet size in the warmer weather and you'll find it becomes slightly more responsive.
Still if that is the only mods you have, I don't think that it'll make that much of a difference in overall output. You have to get air moving through the motor from the front and back for the reeds to be the most help.
Old Dec 10, 2001 | 03:49 PM
MUDDY4LIFE's Avatar
Mike and Ken,
thank you for your response.I do in fact have other mods.I have a PSI pipe w/stock Scrambler silencer.I also done the RcR airbox mod with a KN filter.I have a Heel Clickers clutch kit and went from a 36 tooth rear sprocket to a 38 tooth rear.Im running SideWinders 250 dollar sprockets/chain.I am currently running a 220 main and the plug looks great.
We must also keep in mind that im running some HUGE 26 inch x 12 inch wide rear Mudrunners and 26 inch x 9 inch wide Mudrunner front tires?These require ALOT of extra power from the engine/clutching vs a STOCK engine,so I would'nt notice the gains as readily as someone running stock tires.
Happy Trailing,
Bill
Old Dec 10, 2001 | 06:11 PM
"THANKS" for the info I am new to the sight and I am already finding alot of useful information
Old Dec 10, 2001 | 06:25 PM
Jack's Avatar
Madscrambler --
It all depends on what you have done to your engine. The choice of v-force or boyesen is negligible "unless" you have taken the correct steps to improve the intake/exhaust of your entire system. On a stock setup, don't do it. If your engine has been modified you can expect the v-force to be "slightly" better on top, but the Boyesen setup will give better throttle response throughout the range.
Trader Jack
www.godigital-design.com/schultzmotorsports
