4-stroke exhaust gas temp - Raptor
Old Dec 13, 2001 | 01:14 PM
FISHER1648's Avatar
Does anybody have an idea of how hot the header-to-silencer junction gets on a tpical 4-stroke. In this case I'm thinking of a Raptor?
I recently installed an FMF slip-on spark arrestor and I am getting a slight leak where it meets the stock head-pipe. When the system heats up, it seals but makes a mess until it gets hot. There is no clamp or anything that makes a positive seal (like stock). I was thinking of a dab of high temp silicone or something - any ideas ?? FMF says "that's normal" !?!
Old Dec 13, 2001 | 01:43 PM
raptor720's Avatar
That is one of the problems with the FMF tip. I suggest the Yamaha GYTR or HMF tip. The Yamaha tip has a great seal and clamp. (On occasion, I have found it necessary to cut the compression slots slightly wider for a proper seal)
Old Dec 13, 2001 | 02:27 PM
RaptorRidingOut's Avatar
I also have an FMF pipe on my Raptor...I love it, dont have any leaking or mess that u talk of...but my header gets real hat every time i ride in jeans i come home with a hole in my pants....plus if u ride a night the header will turn red sometimes.....
Old Dec 13, 2001 | 07:33 PM
rraptorr13's Avatar
Check your stock silencer there was a woven copper gasket in there. It is tought to get out but it can be done or you can order a new one from Yamaha. Had the same problem originally
Old Dec 13, 2001 | 09:36 PM
FISHER1648's Avatar
I noticed the gasket, but there is no positive pressure pushing the pipe against it?? It didnt seem like it would do anything without a clamp. Also, FMF said that it was not needed and it's not even mentioned in the instructions. I'll pull it apart and give it a try !
Any other ideas out there ??
Old Dec 14, 2001 | 07:20 AM
rraptorr13's Avatar
White Bros. didnt say anything either but I noticed the leak right off. So I started to poke around and ask a few questions here. Someone told me about the gasket. My pipe was just that much larger in diameter that the fit is perfect with the gasket. No more leak.
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
ltrmc02
Jul 22, 2015 04:50 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
