FLAT TRACK TIRES?
Old Feb 6, 2000 | 05:44 PM
hardlydangerous's Avatar
Im goin to be racin the CMA Flat track circut this year and I still need some parts and info,does any one know what is the best size and make of tire for speedway and 1/2 mile tracks on a 86 TRX250R what rubber compound and tire presures ?any help at all would be great thanx
Old Feb 9, 2000 | 02:14 PM
WAYMOD's Avatar
The answer to your question is not an easy one. Every track you go to will need a differant set up. Softer tires, wider stance, shorter swing-arm less jack in your sway bar.
This is the reason that you hear people say that set us 90% of the game. For a starting point yry this.
18x10x6 Mcreary SD23 compound fronts
18x10x8 Mcreary SD38 compound rears
Sway bar set to neutral (crank on one side of the sway bar or the other in order to make the rear tires weigh the same you will need bathroom scales to do this)
-2" swing arm ( 2inches shorter than an '88 4trax or 3 1/8 inch shorter than 86/87 4trax)
Other than that its up to you and how good you can read your quad and understand the track. As a general rule for circle track races your gonna want to put some jack ( more weigh ) on the front right and left rear.
Good luck the learning curve starts now...
Waymod
Old Feb 9, 2000 | 02:17 PM
WAYMOD's Avatar
18x10x6 Mcreary SD23 compound fronts 10psi
18x10x8 Mcreary SD38 compound rears 5 to 15psi
Waymod
Old Feb 9, 2000 | 02:39 PM
WAYMOD's Avatar
Waymod
Old Feb 9, 2000 | 05:57 PM
WAYMOD's Avatar
Waymod
Old Feb 10, 2000 | 09:37 AM
WAYMOD's Avatar
Waymod
2quiker
Mar 22, 2022 08:36 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
89Lt250r
Sep 7, 2015 07:53 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
