650 shifting
Old Jan 1, 2002 | 01:27 AM
bigddoney's Avatar
when i plow i have to roll my wheeler back and forth to shift.thats when i am sitting still not moving ,is this a shift linkage adjustment?
Old Jan 1, 2002 | 02:04 AM
nyroc's Avatar
No. The gears are not synchromesh, they line up just right and you can't move the shifter, but you rock the quad back and forth a touch and you can shift. Many people tell me most automatic quads with the High, Low Reverse do that. Some worse than others.
If you had a bayou, foreman, big bear, or suzuki before this 650, it had a different transmission design that did not do this. I think pretty much all full automatics do it.
If you just give the throttle the teeniest little bit of throttle, it will move the gears ever so slightly and it will shift instead of having to rock it. I use my left hand to shift, right hand to give a touch of gas in case the gears line up and it won't shift. Works pretty well.
If you turn the idle speed up just a touch, it may alleviate it. It may also make the gears grind, so use your own smarts to decide. Please do not sue me if it causes premature tranny wear.
Old Jan 3, 2002 | 07:39 PM
Dextreme's Avatar
I noticed on my 650 that once it was broken in, it engaged smoother. Only occasionally do I have to have to rock it back and forth the engage it.
Old Jan 5, 2002 | 06:25 AM
500DUSE's Avatar
Yoo kawi guys,
Us polaris guys have this problem also.It's easily fixed by adjusting the shifter linkage.Ours has a lock nut on the shifter linkage rods,loosen those and adjust the rod.It takes about 5mins
Old Jan 5, 2002 | 03:33 PM
Scram500Man's Avatar
I have not had this happen to me at all. I did have a linkage problem which was corrected but even then I could shift through the gears without any hesitation or resistance. From time to time going into H I will get a very quick gear ratchet so maybe Nyrocs theory is correct that idle adjustment will cure your problem. I wouldnt worry about premature tranny wear if the idle theory is correct the split second it takes for the engagement noise I hear is not severe in the least. I would compare it to the way a motocross bike will engage into first if your sitting on the line reving the engine and then put it into first (while the clutcth is pulled in of course).
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
