front hub seal??
Old Jan 1, 2002 | 04:57 PM
boneylong's Avatar
i had my 400 xplorer serviced at the dealer last week //all the fluids changed and so on/i brought it home and havent rode it half a mile and put it up.i noticed yesterday oil was on the floor at left front wheel.what do i do to fix this??
Old Jan 1, 2002 | 05:08 PM
GE4x4's Avatar
Where was the oil coming out, near the seal or the allen bolt where to check the oil.Was the allen bolt on tight, if it was just serviced they might have forgotten to tighten it up.
Old Jan 1, 2002 | 05:19 PM
boneylong's Avatar
inside the front wheel//all over the disc .i read a search on this and someone said that the seal could be adjusted//is that true??
Old Jan 1, 2002 | 05:34 PM
MUDDY4LIFE's Avatar
Your problem is either the hub seal or the sleeve it rides on,or BOTH.My Xplorer's hubs have also leaked alot.Both side's have been done at least three times allready in less than two yrs time.
Bill
Old Jan 1, 2002 | 05:36 PM
GE4x4's Avatar
I don't believe the are adjustable, did you do any front end work to it before they serviced it. Did they do any hub work to it. Also lift up your wheel and try to move it side to side and top to bottom.
Old Jan 1, 2002 | 06:34 PM
kukerdan's Avatar
i filled my hubs and a week later they where empty, now my awd wont even engage
Old Jan 1, 2002 | 06:50 PM
GE4x4's Avatar
Not saying this is it, but when seals, bearings and the AWD not engage sometimes is the result of incorrect bearing adjustment, torqueing the spindle nut to much. The torque should be for the spindle nut is 9-12ftlbs. Just a thought!
Old Jan 1, 2002 | 08:35 PM
Crawdad's Avatar
Sounds like Boneylong & Kukerdan may be in need of new hub seals. Don't want to run them when they're dry. They're not difficult to replace if you have a manual.
Old Jan 1, 2002 | 09:02 PM
kukerdan's Avatar
how much do new seals cost?
Old Jan 1, 2002 | 11:33 PM
boneylong's Avatar
i took my tire off and cleaned everything up good and refilled with oil///it was leaking around the outside cap and running to the back towards the disc and falling down on the wheel..they pinched the seal.i fixed it now..thanks everyone..
