2002 Rancher ES 350
Old Jan 6, 2002 | 11:54 PM
JWP's Avatar
JWP
[img]i/expressions/face-icon-small-smile.gif[/img]May buy a Rancher 350 2 wheel drive.Need information on the electric shift.Has anyone had trouble with it?
Old Jan 7, 2002 | 08:16 AM
trx450's Avatar
I ride with a lot of ES (350/450) owners. Have heard very few complaints. If I buy another Honda, it will be ES, or auto. Just keep checking the various forums, hopefully you'll get some input. Check in "High-Lifter", and "ATV-Time" forums.
Old Jan 7, 2002 | 09:50 AM
TRX350dude's Avatar
no problems here since i took it in for the recall on the shiftplate
Old Jan 7, 2002 | 02:43 PM
LogLeaper's Avatar
jwp, the Es system is great once you get use to it, a couple of rides and it'll be no problem. I like it alot but the wife doesn't, to each his own. It doesn't allow for pop the clutch wheeling take-offs because of the 3000 rpm rev limter from neutral, but if you high rev it in first and pop it to second, it'll get off the ground no problem. I have 1200 miles on mine and the only problem I had was last week (20 degrees in mich) rode for 25 miles, no problems just like normal, washed it after driving on the freeway for 60 miles went to unload it, shifted to reverse no problem , down the ramp, went to shift to first, NOTHING, did wash the quad really good though got water in the ES shifter possibly and froze, took out the old foot shifter just to see if it worked and sure enough, 1st,2nd,... worked the gears alittle let it warm up and presto, back in business, working just fine again. The shifting tool works well but you wouldn't catch me riding it like that...
I personally do alot of mud/water riding even in the winter (though normally frozen, lol) and would not like to dump the quad in a creek and FREEZE up the ES system, this is the first time not working, sank it many times in the summer, never a problem, but the winter ??? be careful if you ride frozen rivers that is. I love the high performance a clutch system offers, but the ES system is REALLY NICE. I can also climb on my quad(es) shift and never get wet or muddy...... but that's ALL of the FUN isn't it....
trx350dude, shiftplate re-call ???? when ??? what serial #'s, I have a 2001 2X4 ES, any info....
Scott
01' Rancher ES
91' KX80 (race ready)
Old Jan 7, 2002 | 04:53 PM
Buckeye400EX's Avatar
My little bro just bought a Rancher ES. I've ridden it numerous times. He hasn't had ANY problems with the shifting. We went together when he got it. I was ready to talk him in to a S model. But you get more than just the electric shifting for the 200-300 dollars more for the ES. You get full floorboards, you get the digital dash with speed, hour/trip meter and odometer. So I think it's worth it, even though every time I get on the thing, I'm tapping my toe to downshift. HA! Takes some getting used to hitting it with your thumb.
Old Jan 7, 2002 | 08:58 PM
gohl's Avatar
I bought my ES in October 2000. Some pro's and con's...
Pro's:
Faster to shift for less momentum loss going up hill.
Faster to shift for quicker acceleration.
Full floorboards.
Speadometer cluster.
Water crossings...I change gears and keep my feet dry.
Con's:
If I come to a stop and have not downshifted it tends to stick alittle while downshifting through multiple gears.
Twice it has stopped working...I turned the key off, then on and it was fine.
Also...It does take some getting used to. Once you get the hang of it I'm convinced you'll love it. Downshifting while going up hills has been a huge unexpected advantage.
If I could only get Honda to give it selectable on the fly 4wd, disk brakes, independent rear suspension and brake lights I would have the perfect quad!
Buy the ES, you won't be sorry!
Old Jan 8, 2002 | 07:39 AM
trx450's Avatar
gohl--- Check your private messages.
Old Jan 28, 2002 | 05:20 PM
shotguncreek's Avatar
On the TRX350ES, not only do you get the floorboards, LCD Instrument Cluster, and Electric Shift, but you also get the Oil Cooler Fan, none of which come on the 2WD Manual Shift model. The cost of the fan cooling kit alone is a $279.87 option, the LCD package a $168.11 option.
Old Feb 3, 2002 | 10:01 AM
redhondarancheres's Avatar
I have a 2002 Honda Rancher Es 2x4 and i've had no problems yet. Cant say that for my bud who has a 2001 rancherS he shattered his plastic
Old Feb 3, 2002 | 10:37 AM
350X's Avatar
Logleaper, I am sure only the 2000 models needed the recall/upgrade. 2001 models should be upgraded from the factory. Karl
