Anybody Running a Digatron For EGT, RPM, and Coolant Temp???
Old Jan 8, 2002 | 04:12 PM
walexa's Avatar
Hey guys...........I'm trying to find a Digatron Guage that will allow me to monitor EGT, RPM, and Coolant temperature. It doesn't have to be 3 displays..........but possibly a single display with the option to toggle between outputs. I could obtain the same results using 2 or 3 different guages, but I really want to keep things looking simple and not have 3 different guages hanging on my handle bars. Any help is greatly appreciated.
Waylan
Old Jan 8, 2002 | 08:17 PM
Ronnnnn's Avatar
Check this place out. I am running the Hottach if you got any questions.
http://www.exhaustgas.com/
Old Jan 9, 2002 | 01:59 PM
DaveB's Avatar
I have a Digatron 32sn that I run on my sled. Has 2 EGT inputs and a tach, with max recall and snapshot feature. I just replaced the probes on my sled so I'm going to put the 1 good old one on the 400 Scram, then pick up a wat temp probe for the other EGT input. Should work lovely!
Old Jan 9, 2002 | 03:51 PM
walexa's Avatar
Thanks for the info guys. It is so hard to find websites using search engines.
I called RCR yesterday to check on the status of my engine rebuild, and discussed buying an EGT with Rick. He stated that although it can be a good tuning tool, it probably won't be necessary to get mine jetted right. I'm still interested in a digital coolant guage, but I can't find much info on them.
Thanks again,
Waylan
Old Jan 9, 2002 | 06:12 PM
Ronnnnn's Avatar
I run a cooland probe on mine, along with a EGT and a few other things, so far everything works perfect. I use mine mainly to record a race and then look at the data after.
Old Jan 31, 2003 | 10:26 PM
raptorinmexico's Avatar
Default Anybody Running a Digatron For EGT, RPM, and Coolant Temp???
Ronnnnn,
I am thinking about buying an EGT sensor and I observed in your posts that you were using the Hottach EGT sensor. Is this a useful tool for fine tuning the jetting? Was it worth the purchase? Easy installation?
Thanks
Old Jan 31, 2003 | 10:37 PM
Ronnnnn's Avatar
yes, i am running the "Hottach Pro" from exhaust gas technologies, it will do alot of things, probally not needed but are nice to have.
Old Jan 31, 2003 | 11:09 PM
FTZLT250r's Avatar
I hear they work even better when they are installed on the quad........................ [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 31, 2003 | 11:24 PM
SHOTGUN's Avatar
I'm using a digatron, its a playback.
digatron
It works good
Old Feb 1, 2003 | 01:56 AM
aussiequadrider's Avatar
G'day Shotgun. Which model digitron are you running, & where did you get it ? I'm thinking of the Dt 52k max model for my predator. EGT = engine gas ------? Thanks from down under, Geoff.
