Do I remove old oil pump wiring from crankcase?????
Old Jan 10, 2002 | 05:47 AM
stinky's Avatar
Just finished installing oil injection block kit,
Took a little longer than expected, that damn left hand screw.....Grrrrrr.
Just wondering if I need to remove the pump wiring that goes into the crankcase??
Any advice would be appricated.....Thx
Old Jan 10, 2002 | 05:16 PM
williewonka71's Avatar
what wiring?
Old Jan 10, 2002 | 05:22 PM
stinky's Avatar
I removed pump, shaft with spline on it etc, installed plug & block off plate, then unplugged loom at oil tank & removed tank. Now the loom I unplugged is now hanging on its own, this loom runs bach to the crankcase about 1" above where I installed the block off plate..
Old Jan 10, 2002 | 05:30 PM
Chunky5678's Avatar
Two days ago I removed my oil injection from a 2001 Scrambler 400 and there was no wiring except the gizmo box on top of my oil tank. I kept that one because my quad won't start without it.
Is this a TB or 400?
Chunky
Old Jan 10, 2002 | 09:23 PM
stinky's Avatar
This is a TB, Thx..
Old Feb 22, 2004 | 11:27 AM
69camino69's Avatar
Default Do I remove old oil pump wiring from crankcase?????
how do you get the splined shaft out, thank you
Old Feb 22, 2004 | 11:54 AM
ScrambleMe's Avatar
I ve seen your posts 69 but couldnt understand so I went out and looked at the one I removed.. dont know if its the same. but did you remove the two screws holding the the whole inner mechanism in?
Old Feb 22, 2004 | 12:35 PM
69camino69's Avatar
thank you for the response, took the 2 screws off and the pump itself comes off, now the actual pump drive is still left in the crankcase, i can see how you could just put plate on and cover it up, but the drive would still be driven by the crank and bouncing around in there, am i way off here, please let me know
Old Feb 22, 2004 | 12:37 PM
69camino69's Avatar
sorry guys but i didnt mention that mine is a tb250 , 2002 model, is it different than the 400
Old Feb 22, 2004 | 04:30 PM
ScrambleMe's Avatar
i wonder if the 250 eliminator kit is suppose to have something to secure the drive gear in place. its gotta be different than the 400 w/ just a block off plate. try calling aaen or hot seat. i remember when i got mine the parts guy said mine was missing a part, so he called and they said that was all that was needed for the 400. Makes me think there has gotta be something else, also looked it up on aaens site and it lists two kits one for 350/400 and one for 250. sorry i dont have a quick answer, you'd think someone would. good luck.
